Swap Problems
I'm having problems with my swap.
1. I dont have any clutch. I think I hooked it up correctly.
2. I'm have a coolant leak that looks like its comming from the crankshaft area? I dont know whats going on with that.
3. It always cranks but then never really turns over it just will go pop, pop, and die
Please help me if you know whats going on?
Nick
Nick
what your set-up? ok, without knowing that i try to help you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sinner »</TD></TR><TR><TD CLASS="quote">1. I dont have any clutch. I think I hooked it up correctly.</TD></TR></TABLE>
try and bleed your clutch slave cylinder.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sinner »</TD></TR><TR><TD CLASS="quote">2. I'm have a coolant leak that looks like its comming from the crankshaft area? I dont know whats going on with that.</TD></TR></TABLE>
That maybe your water pump that is leaking
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sinner »</TD></TR><TR><TD CLASS="quote">3. It always cranks but then never really turns over it just will go pop, pop, and die</TD></TR></TABLE>
I think that your timing is off, check the firing order and cam timing.
I hope that helps you!
spyderpaint88
Mar 15, 2008 09:10 PM
