Motor swap question 86 crx si
I have a 86 crx si with the 1.5 i also have a 2.0 prelude si motor and tranny. The valve covers are the same. Will this swap work? Will the injectors from the 1.5 fit the 2.0? header,intake,tranny,ecu? Any help would be great.
Re: Motor swap question 86 crx si (Mag13)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mag13 »</TD></TR><TR><TD CLASS="quote">I have a 86 crx si with the 1.5</TD></TR></TABLE>
No such thing. You either have an 86 CRX Si with a 1.6 or it's not an Si.
No its a 1.5 the 88 is a 1.6
Go do some reading. From 85-87 Civic/CRX came with a 1488cc EFI or CARB.
1488cc = 1.5 not a 1.6
Modified by Mag13 at 1:28 AM 5/28/2003
Yep the si was 1.5ltr in 86.
IMO that swap is not worth the hassle, your best be to is to purchase a b16a and drop it in. it will drop rite in with the help of some hasport mounts and everything else is strait forward.Luckly you have the si otherwise it would be a big pain in the *** to convert to fuel injection.
Schaz
16
09-03-2004 02:11 PM
