re to A9Code 14 IACV help!!!
Old May 26, 2003 | 07:30 AM
UpstateCivic's Avatar
Default Code 14 IACV help!!!
So I'm only throwing 1 code now, for IACV. Well I wired it up, ran 1 wire to A9, and i grounded the other right to the engine. It went away for about 2 minutes, and then it came back and has been there ever since. Is A9 not the right spot for it or what?
Old May 26, 2003 | 11:04 AM
poison's Avatar
Default Re: Code 14 IACV help!!! (UpstateCivic)
Yes, A9 is the correct place. It also needs a power source with a Yel/Blk wire.
Not a ground
Grab a Digital Multimeter and verify there is no open circuit in the A9 wire, going to the ECU. Also make sure the Yel/Blk power wire is wired up properly.
You can tap that into B1 or A25.
If you know wiring is good, then the IACV is faulty.
HTH man
Old May 26, 2003 | 06:36 PM
Hondasaurs's Avatar
Default Re: Code 14 IACV help!!! (poison)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison &raquo;</TD></TR><TR><TD CLASS="quote">
You can tap that into B1 or A25.</TD></TR></TABLE>
This is where the Yel/Black wire needs to go?
Old May 26, 2003 | 06:57 PM
Turbogixxer's Avatar
Default Re: Code 14 IACV help!!! (B17A Hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B17A Hatch &raquo;</TD></TR><TR><TD CLASS="quote">This is where the Yel/Black wire needs to go?</TD></TR></TABLE>
Yeah, we are both ECU power sources, it does not matter which one you use cause they are the same.
Old May 26, 2003 | 07:01 PM
Hondasaurs's Avatar
Default Re: Code 14 IACV help!!! (turbogixxer)
Thanks. I got bogus info before and grounded one side of the plug.
fergs96integra
Audio / Security / Video
23
May 22, 2006 09:17 AM
94EeGe
Sep 17, 2004 11:42 AM
PhazedSI
Feb 14, 2004 09:47 PM
cd5_2NR
Apr 20, 2003 09:47 PM
XxCIVICxX
20
Apr 17, 2003 11:44 AM
