h22 injectors
Old May 26, 2003 | 09:37 AM
nos_b16's Avatar
Default h22 injectors
Hey i got a quick question i just picked up from a friend some 370cc rc injectors but will they work with my h22 since i have the injector resistor box....they are obd1 injectors?
Old May 26, 2003 | 10:56 AM
poison's Avatar
Default Re: h22 injectors (nos_b16)
Yes, they will go in with a resistor box and your motor being OBD1.
Old May 26, 2003 | 11:09 AM
nos_b16's Avatar
Default Re: h22 injectors (poison)
but i dont think there peak hold so if there not i can just by-pass the injector resistor box correct?i got them for free so...
Old May 26, 2003 | 11:11 AM
poison's Avatar
Peak hold will be fine if you have stock internals/head.
Old May 26, 2003 | 11:15 AM
nos_b16's Avatar
the 370 rc's i have i think arent peak and hold i believe u can tell because where the injector clip slide in theres a little groove on peak and hold injectors and on regluar there isnt?
Old May 26, 2003 | 01:06 PM
Carnut
Guest
Posts: n/a
werent the OBD1 injectors peak and hold and that is why they usethe resistor box....as opposed to OBDII which were Saturated switch injectors.....if you have an OBD I engine and ECU it shoudln't matter, right
Old May 26, 2003 | 03:55 PM
junglerunna's Avatar
Default Re: h22 injectors (Carnut)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Carnut &raquo;</TD></TR><TR><TD CLASS="quote">werent the OBD1 injectors peak and hold and that is why they usethe resistor box....as opposed to OBDII which were Saturated switch injectors.....if you have an OBD I engine and ECU it shoudln't matter, right </TD></TR></TABLE>
WEll the resistor box is used to lower the voltage.
Prudz_lude
Oct 15, 2014 06:44 AM
accordin 2 me
Dec 16, 2011 06:00 AM
Brownjd
Feb 7, 2011 02:00 PM
e jay one
Aug 6, 2005 02:48 PM
BoostedJeff
Oct 31, 2004 05:09 PM
