Daily Driver Compression Ratios
Old May 28, 2003 | 07:32 AM
jDMJeRk's Avatar
Default Daily Driver Compression Ratios
Im currently in the process of stroking my b16 to 2.12L with the Crower Stroker Kit.(http://www.crower.com/cat/import/honda/stroker.shtml)
I need to order the kit soon; but I cant make up my mind on the compression ratio. The mechanic tells me that 11:1 is pushing it. But how can that be pushing it if the USDM iTR is 11:1. The machine shop that is sleeving my block, doing some machine work as well as installing the stroker kit explained to me that if I were to go any higher (11:1+)my bottom end will not last as long if I were to go a little lower. On the other hand a local POS speed shop told me that they have hatchbacks with compression ratios up to 13:5:1 on 92 octane gas (highest you can get up here in WA)....Over all Im stuck; can someone fill me in on these compression ratios and extactly what I'm getting into. This car is going to be a daily driver and I want to get AT least 75,000k-100,00k out of the motor. So what is my best bet. 12:1 or 11:1. Im going NA and plan to do proper work to the head. Im just focusing on the bottom end first. Thanks guys
Old May 28, 2003 | 03:32 PM
roadawg's Avatar
Default Re: Daily Driver Compression Ratios (jdmjerk)
I'd say go with 11 to 1. Although 12 to 1 would be possible also. The general difference in power between 1 number in CR is 8 -12 HP. So the difference in HP would be around 10 HP difference between 11/1 and 12/1. Other mods done to the engine would of course change this theory. And dont forget if you're doing head work down the road, like a thinner head gasket, that will increase the CR even more so 11/1 is plenty, IMO.
Boostage
Jun 15, 2010 05:07 PM
Aaran
Apr 13, 2005 01:34 PM
brookliner7
Dec 7, 2004 06:59 AM
wm5holla
Jan 7, 2003 07:06 AM
