Moving wires at ECU..how do you do it?
Hi,
Just finishing up my B20 swap and I was wondering: how do you move the wires at the ecu plugs on the wiring harness?
I have to move the wire at A14 to A12 for the IACV ground (don't remember off the top of my head)...but how can you take that wire out and put it in the other slot cleanly and without breaking it?
Thanks
Thanks
Re: Moving wires at ECU..how do you do it? (DevinW)
I don't know if you would call this 'ghetto', but when I move a wire from one place to the other, it's one pain in the *** to get out the whole pin. I cut the wire and solder it to the other wire.
Use heat wrapping and put the black wire cover back on.
HTH.
HTH.
Re: Moving wires at ECU..how do you do it? (poison)
its pretty hard to describe and even harder to do but I used a paper clip and it took me forever, once you figure it out it's a breeze.
That works well when there is another wire to connect to, but I think his question is, how do you pull a pin from the connector to a spot that has no pin in it at all.
Re: Moving wires at ECU..how do you do it? (AudioFuct)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AudioFuct »</TD></TR><TR><TD CLASS="quote">That works well when there is another wire to connect to, but I think his question is, how do you pull a pin from the connector to a spot that has no pin in it at all. </TD></TR></TABLE>
This is true. Thanks for the correction
here is a link for a how to on repinning the ECU harness for a fifth and sixth gen civic:
http://www.deepstaged.net/rpecu5gci.htm
this is how to repin the female gray plug for the same generations civics/integra:
http://www.deepstaged.net/rpeh5gf.htm
and for the male gray plugs:
http://www.deepstaged.net/rpeh5gm.htm
and the entire link for other plugs for other generation civics:
http://www.deepstaged.net/repin.htm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison »</TD></TR><TR><TD CLASS="quote">listen to him!! he knows!
by far cleanest installations i've seen yo. </TD></TR></TABLE>
ooookay?
there is no reason to mock me because i have expressed my gratitude towards the help you have provided me.
but, if for some reason you have a chip on your shoulder or you have a problem with me personally, just IM me and we can discuss this matter.
Modified by Hatch4urSnatch at 2:48 AM 5/23/2003
ooookay?
Re: Moving wires at ECU..how do you do it? (Hatch4urSnatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatch4urSnatch »</TD></TR><TR><TD CLASS="quote">
ooookay?
Modified by Hatch4urSnatch at 2:48 AM 5/23/2003</TD></TR></TABLE>
what? nooooo man. now you took it the wrong way.
I was in no way mocking you. You do very clean work and have every right to take pride for the clean wiring and ideas you have done. I felt very priveledged to help ya out in any way I could.
I give you my upmost respect for the work you have done with your swap and very much appreciate you assisting the creator of this thread.
I sincerely apologize if you have taken it the wrong way.
Don't take it the wrong way man.
ooookay?
so, how did it work out? were you able to move the wires with the aid of the links?
sorry to bring this back up but...what about if you want to add a new wire to the male ecu plug in a 6th gen? where can you get the little rubber/metal pieces on the end of the wire? or can they be reused?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatch4urSnatch »</TD></TR><TR><TD CLASS="quote">here is a link for a how to on repinning the ECU harness for a fifth and sixth gen civic:
that's the cleanest and probably the right way of doing that in the first place.
Re: Moving wires at ECU..how do you do it? (2000CX)
Well we haven't done it yet because we ran into bigger problems with the transmission...
90_EX_Civic
03-21-2009 07:59 PM
freeplay
Audio / Security / Video
24
03-13-2004 09:06 AM
streetstylenperformance
02-26-2004 03:28 PM
