98 gsr master cylinder any other brake booster fit it????
Have a new 98 gsr master cylinder but I was curious to know if the stock civic brake booster will fit or what year integra's will work on it? thanks
Re: 98 gsr master cylinder any other brake booster fit it???? (superflea)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by superflea »</TD></TR><TR><TD CLASS="quote">Have a new 98 gsr master cylinder but I was curious to know if the stock civic brake booster will fit or what year integra's will work on it? thanks</TD></TR></TABLE>
The civic booster will not fit the teg cylinder. You will need the power booster for the teg as well. Also, your teg booster is most likely for ABS, which means you will need to modify the lines on the civic to accept the larger fitting as well as do some bending.
New User
Re: 98 gsr master cylinder any other brake booster fit it???? (Hybrid93Eg)
95BlkGSR
06-23-2005 09:52 PM
trustnoone7935
04-13-2005 10:49 PM
