Lsvtec feed line
Old Jun 14, 2014 | 07:55 PM
tiemze's Avatar
Default Lsvtec feed line
I have a regular BWR oil sandwhich plate with 3 1/8 npt ports. My question is can I use this for lsvtec. I know you need a - 6 an feed. Can you use a 1/8 to -6 converter?
Will the 1/8 be enough. I see on the Golden eagle kit the fitting is much larger. But other lsvtec kits use the oem oil pressure sensor port which is 1/8".
Old Jun 14, 2014 | 07:59 PM
F22Master's Avatar
Default Re: Lsvtec feed line
I am using a 1/8 to -6 converter, but I drilled all of my fittings out as much as I can. I couldn't go too large, but its a decent bit bigger than they were...
Old Jun 14, 2014 | 11:49 PM
tiemze's Avatar
interesting, what made you decide to drill them?
Old Jun 15, 2014 | 12:21 AM
F22Master's Avatar
More volume.
Maybe they would have been fine undrilled, but can more oil hurt?
Old Jun 15, 2014 | 10:11 AM
tiemze's Avatar
I'm sure not. But just wanted to clarify, r u using a sandwich plate?
Old Jun 15, 2014 | 11:37 AM
F22Master's Avatar
No I am not. I am using the stock oil pressure sender location. But still, a 1/8 npt fitting is an 1/8npt fitting, no matter where it is getting its source from
Old Jun 15, 2014 | 01:32 PM
tiemze's Avatar
Oh ok was just wondering if there was a differnece with using a sandwich.
Old Jun 15, 2014 | 01:56 PM
F22Master's Avatar
There shouldnt be. The oil pressure at both locations is pretty much identical, and since it has to pass through the same size orfice in either location, flow will be the same.
Old Jun 15, 2014 | 07:58 PM
tiemze's Avatar
Ok I think I might go for it.
I'll just get this kit
http://www.ebay.com/itm/331225977960
And a 1/8 npt tap for 5 bucks. Already got dowels from my old gsr. Nevermind apparently ls stud holes are smaller than their vtec counterparts so I'll need new dowel pins
javantie
Apr 22, 2015 02:10 PM
VitaD16
Mar 13, 2014 11:28 PM
ivan93egreppin210
Jun 11, 2008 12:04 PM
ivan93egreppin210
Jun 6, 2008 09:04 AM
cdog19
Feb 9, 2004 01:15 PM
