H22 ek code 9 and jumpy tach
Old Jun 4, 2014 | 06:03 PM
puresteez's Avatar
Default H22 ek code 9 and jumpy tach
Hey ht, just put a new h22 in my ek because the old ones journal bearings seized to the crank. im getting code 9 cel, my tach is jumpy, and the car runs like a bag of ****.
its running p28 with s300, h22a1
had this all running nicely before and now i cant figure out whats causing the problem.
any ideas?
Old Jun 4, 2014 | 06:09 PM
puresteez's Avatar
Default Re: H22 ek code 9 and jumpy tach
td60u dizzy, just checked resistance between pins 4 and 8 got 413 ohms
Old Jun 4, 2014 | 06:24 PM
puresteez's Avatar
just looked at low speed ignition tables in the smanager, the revs the ecu is seeing are jumping from 750 to 1750, i can rev it above that but it will jump almost 3000 rpm according to smanager
Old Jun 5, 2014 | 08:57 PM
HiProfile's Avatar
Same distributor? Then you probably nicked a wire or just got unlucky with a failing ICM.
Different distributor? Then you probably just got unlucky with a failing ICM.
Old Jun 7, 2014 | 11:43 AM
puresteez's Avatar
I swapped out the cyp sensor with a spare I had and its running fine now. Seems to be misfiring at wot with hesitation at 3k then 5k rpm and won't go into VTEC,
TheAccordGuy
May 22, 2006 01:22 PM
vtec420kingH22
Mar 7, 2005 11:26 AM
Jago
Sep 25, 2004 03:45 PM
Ddogz15
Mar 22, 2004 09:54 PM
