bogging and clicking issue???
Old Jun 2, 2014 | 09:31 AM
scoker83's Avatar
Default bogging and clicking issue???
So just in the last week my car has developed a very slight bog/hesitation while cruising in low rpms - not all the time and usually in 4th gear between 2000-3500k. If I get in the throttle a little bit it goes away. Also when it's running like this if I press in the clutch and let the rpms fall to idle you can here a weird clicking sound.l that I've never heard before....
Car: 00 civic ex
Engine: B18c r spec w/ matching p73 ecu.
I've cleaned and checked connections to all sensors. New cap, rotor, plugs, wires. No CEL's.
I know it could be a thousand things but any help pointing me in the right direction to diagnose this problem would be great.
Old Jun 2, 2014 | 12:53 PM
scoker83's Avatar
Default Re: bogging and clicking issue???
Bump
Old Jun 2, 2014 | 05:17 PM
scoker83's Avatar
It only happens after going wide open throttle high enough for vtec, and just for a minute or two then it goes away...
Old Jun 3, 2014 | 08:17 AM
Sonin Fury's Avatar
I dont know if this is related, but the last weird issue I just had with my B18C was because of a loose ground, specifically my thermostat ground.
Old Jun 3, 2014 | 10:17 AM
scoker83's Avatar
I cleaned/checked all three last night because all my lights are dimming too. No change. Not sure if it's related...
Thanks
Old Jun 3, 2014 | 12:03 PM
scoker83's Avatar
Bump for a weird clicking sound.... The only thing I can compare the sound to is a hot wire sparking on some metal.... I've checked the harness, alt and grounds. It only hesitates and makes the clicking sound after reving high enough for vtec. If I stay under 5.5k it'll drive fine all day
Old Jun 3, 2014 | 03:19 PM
scoker83's Avatar
Nobody???
scoker83
22
Jun 12, 2014 09:08 PM
varrinb18c
Feb 12, 2009 12:58 PM
9WON4
13
Jun 14, 2006 04:16 PM
littlegreenb18
12
Apr 13, 2006 02:26 PM
