B20Vtec Sleeve Question
Old Jul 24, 2014 | 04:53 AM
BigJerm333's Avatar
Default B20Vtec Sleeve Question
I'm in the process of starting a B20 build. Here is what I'm planning on running. It's going to be RS Machine 84.5 high compression pistons. Shot peened stock rods. ACL Bearings. ARP rod bolts. Golden Eagle block guard. GSR head. How safe will the stock sleeves be on a setup like this? When I search some say to sleeve some say it's ok not to. I want a strong and reliable engine but want to try and keep the cost down as much as possible. Thanks.
Old Jul 24, 2014 | 05:04 AM
sixstroke's Avatar
Default Re: B20Vtec Sleeve Question
Safe.
Old Jul 24, 2014 | 05:19 AM
Freemananana's Avatar
You're not even close to the limits of the sleeve if you use proper fuel management and prevent knocking.
Old Jul 24, 2014 | 09:06 AM
BigJerm333's Avatar
Ok thanks. I plan on running a chipped ECU and having it professionally tuned. As far as preventing knocking would it be better to tap the block and add a knock sensor?
Old Jul 24, 2014 | 10:11 AM
No. Your tuner will take care of that. Safe AFRs and safe timing maps will prevent knock.
Deej23
K Series
Feb 17, 2014 05:32 AM
ek souljah
Dec 25, 2010 10:38 AM
bertsb18hatch
Jun 8, 2009 07:44 AM
jcivicsib20
Mar 6, 2003 10:31 AM
