91 hb auto X build
91 hb auto X build
Hi, I have a 91 si hb that has been sitting around for many years. I started to focus more on drag racing than auto x because the lack of events in my area.
Now I want to get this car up and kicking again. As of right now, I have:
Innovative front cross member setup
B18a stock (not doing so hot)
B16 cable trans (third gear grinds bad)
Converted to obd1
Da brake booster and master cylinder
4040 proportioning valve
Wilwood 12.19 drilled/slotted rotors w/4 piston calipers
Rear disc brake setup (not installed yet)
Function Form coilovers
16" rota boost wheels
Rear strut bar
I also have a b16 complete head. Im not sure If i should go with a lsv setup or do a crv setup (added mid range of the b20)..? I plan on doing a hydraulic pedal setup so I can go hydraulic trans. I do not want to go turbo. I want to stay in SM class.
Feel free to add input.
Converted to obd1
Rear strut bar
wantboost
Suspension & Brakes
35
03-15-2013 08:51 PM
