integra rear transmission bracket in 96 civic ?
Re: integra rear transmission bracket in 96 civic ?
I had a swap in my old 99 civic it was gsr im not sure what rear bracket was in there though . I know they say the integra one pushes the motor forward. But how far ?
If you use an EG rear subframe/steering rack in an EK chassis, the rear mount location is moved slightly rearward, and thus, requires the slightly longer T-bracket from a '94-01 Integra instead of the '99-00 Civic Si bracket to make the distance. The engine still stays in the same relative position within the engine bay... it is NOT moved further forward because of the above change.
SinsEvil666
12
02-16-2009 04:44 PM
