injectors question
Old Jul 3, 2014 | 12:41 PM
amtheiceman's Avatar
Default injectors question
Quick question. I'm doing a 98 spec type R swap on a odb1 hatch going from a b16. Its it possible to run the b16 injectors on the type R. I've tried searching but there is a lot of mismatch info out there mostly dating as far as 10 years ago. Anyone that can guide me in the right direction thank you
Old Jul 3, 2014 | 12:47 PM
JDM knowledge's Avatar
Default Re: injectors question
from what i recall, yes you can use them. same harness used? and ECU(chipped?)
Old Jul 3, 2014 | 01:13 PM
spAdam's Avatar
Loved
Community Favorite
Yes. Make sure you are using the itr pressure regulator though, it runs .5 bar more pressure than the b16 one.
You should look into an upgrade though, the stock ones are pretty much maxed out on the itr motor... Hence why Honda upped the pressure for that application.
Old Jul 3, 2014 | 01:15 PM
Yes obd1 harness I'll be running it with a hondata s300, type r basemapped
Old Jul 5, 2014 | 10:00 AM
spAdam's Avatar
Loved
Community Favorite
Here, there's already a discussion on pretty much your exact setup:
https://honda-tech.com/forums/showth...3213275&page=2
Old Jul 6, 2014 | 01:51 PM
HiProfile's Avatar
At non-ITR fuel pressure the 240cc injectors will be hard-pressed to hit >160whp. The ITR reg would net ~7% more fuel with an extra 0.5BAR of pressure.
censurebush
Oct 29, 2008 07:41 PM
h2point2
Sep 17, 2007 07:56 AM
_gurusan_
Jun 1, 2005 09:27 PM
W0oT
Jun 13, 2002 05:41 PM
