What ecu to run?
Old Apr 24, 2014 | 06:34 PM
Kid-jdm-teggy's Avatar
Default What ecu to run?
I have a crx si, im in the process of swapping a 99 ls into it. I already converted the dizzy to obd1 and i swapped out the alternator plug from the obd2 motor for an obd0 one. Its all wired up and i was wondering could I just run an obd0 pr4? Or do i need to run an obd1 ecu with a jumper?
Old Apr 25, 2014 | 08:59 PM
Emeraldbomber's Avatar
Obd1. For ease of everything run a p28 with a Ls basemap.
Old Apr 26, 2014 | 02:27 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: What ecu to run?
Did you convert the dizzy plugs to OBD1? You can't mix and match OBD1/2 ECU/Distributor with OBD0 Distributor/ECU. Rule of thumb is OBD0 ECU -> OBD0 Distributor. OBD1/2 ECU -> OBD1/2 Distributor.
whitecivic11
Mar 28, 2010 11:04 AM
munchies91crx
34
Sep 20, 2009 05:59 AM
91dxcrx
Jan 22, 2006 05:46 PM
Maddox
10
Apr 11, 2004 11:24 AM
Dragger817
Oct 29, 2003 06:52 PM
