JDM B20B into 98 CRV
Old 06-23-2014, 06:58 PM
3rdDrawerDown's Avatar
Default JDM B20B into 98 CRV
Hey guys, im looking for some guidance on this swap im doing
I have a 98 CRV, AWD, Auto, that ive recently installed a B20B from HMO.
First thing i noticed is the distributor, the HMO engine is an 8 pin, the original car has a 9 pin. I did some looking around and found this http://technet.ff-squad.com/ckftrick.htm. No problem, i can wire, so that part is dealt with.
Should i just use the 9 pin distributor? Do both of them have CKP sensors? Or just the 8 pin. Or is it even needed doing the ckf trick?
Old 06-24-2014, 12:49 PM
Technical Hero
HondaPartsHero's Avatar
Default Re: JDM B20B into 98 CRV
Use your old one. The JDM engine won't have the CKF which is by the crank pulley not in the distributor and will have to be bypassed.
Old 06-24-2014, 02:38 PM
OK i got it, (bypassed) not rewired to another signal . The CKP will take care of everything.
I appreciate the help guys as i work through this. This is not a rush deal, it can take as long as it takes. Im wanting to learn a few things and get my head back into hondas. I haven't touched anything outside maintenance stuff in 15 years.
Ive got a few other things that need addressing that i have not been able to find anything on by searching. Ill post some pics and questions once i get all my info together.
And if anyone has a FWD crv rear T bracket and auto shift linkage for sale let me know. Apparently those are not the same as the AWD ones.
Old 06-24-2014, 04:28 PM
Technical Hero
Well basically the bypass is wiring it to another signal at the ecu.
Old 07-11-2014, 10:42 PM
Everything is running fine, no engine lights. The motor and tranny HMO sent me was super clean. The CRV should be reliable for the next 10 years lol. Thanks again.
Just in case anyone does a search on this...
If you are changing a CRV from AWD to FWD (Auto tranny), you will need the Rear t bracket and shift linkage off a FWD. There are slight differences. But you may be buying those new, FWD's are tough to find in the yards.
whiskywaterwine
11-30-2017 04:16 PM
black0hatch
Honda CR-V & Element
09-10-2016 05:48 PM
BMaDOHC
03-26-2010 06:36 AM
DvSiR
04-04-2005 09:46 PM
lila98lude
06-09-2004 09:20 PM
Quick Reply: JDM B20B into 98 CRV
