Weid MAP issue
Old May 25, 2014 | 02:31 AM
carlos8's Avatar
Default Weid MAP issue
hi guys, Working on my civic ex 97 LS Vtec with this weird MAP low voltage at pin D17 3.54v
Swap two ECU's
New Map
Wire continuity from ECU pin to plug
Clean g101
Symptoms:
Hard start
bogs and sputter when press gas (neutral)
wideband goo completely to lean
The car at take off bogs and die (not drivable)
Old May 25, 2014 | 07:59 AM
carlos8's Avatar
Default Re: Weird MAP issue
Car idle perfect all day, NO CEL.
REV's with carburetor cleaner.
Old May 31, 2014 | 12:20 PM
94EG8's Avatar
Seagull Management
Default Re: Weid MAP issue
New swap? MAP and TPS plugs switched?
Old May 31, 2014 | 03:33 PM
carlos8's Avatar
No, Sir this swap has like 4 years.
Map and TPS plugs are fine.
This start like a TPS issue, bogging a little at take off, and getting worse to the point that now only stay at idle and sputter and die when press the gas.
NO CEL.
Apart from the fuel system: Pump, filter and regulator (all new) and Distributor (45k from ITR swap). what can cause this type of failure?
New, TPS and MAP.
carlos8
36
May 4, 2014 05:42 AM
ashb82
Engine Management and Tuning
11
Aug 3, 2012 01:22 PM
brutekiller787
Mar 12, 2010 06:12 PM
Running925
Nov 14, 2006 07:57 AM
minititan
Jul 13, 2005 05:02 PM
