B16A wiring identification and help
Old Jun 13, 2014 | 10:03 PM
viperjng's Avatar
Default B16A wiring identification and help
Hi Guys,
Purchased a B16A2 swap online and received today. After opening the crate my mechanic on checking the same has said that 1 harness is missing. AM attaching a pic of the socket where it connects to. Can anyone help identify it and lemme know what its called. A part number or what should i ask for.
As per the mechanic the harness thats missing goes and connects to the fuse box in the car and he cannot fire up the car without that.
Thanks in advance.
Jignesh
Old Jun 14, 2014 | 03:27 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: B16A wiring identification and help
I'm going to assume its a JDM B16A swap? If so it uses a right hand drive harness which can't easily be used in your car if its left hand drive as the sides are swapped. Not sure what car you putting this in but you have a few options. List your year, make and model.
Old Jun 14, 2014 | 05:33 AM
viperjng's Avatar
Hi,
Its a JDM swap purchased from Bangkok. Plan to install it in a RHD Honda City 2nd generation 2002 model sold in Thailand, Malaysia and India
Jignesh
Old Jun 15, 2014 | 09:01 AM
viperjng's Avatar
Noone here can help??
Old Jun 15, 2014 | 09:20 AM
F22Master's Avatar
Like already said, the fusebox connector will be on the other side.
Old Jun 15, 2014 | 08:33 PM
viperjng's Avatar
Hi Guys,
Let me clarify what I need help with.
1> Engine is a JDM B16A2 for use in RHD vehicles.
2> Car is a RHD Honda City
3> Internal fuse box is also on RHS
4> I need the name or part number of what that harness is called as that is what is missing.
I have circled the connectors where the harness needs to connect to. Hope you guys understand what I am asking for. I need to be able to explain the harness thats missing to the engine supplier so he can send it to me.
Jignesh
Old Jun 16, 2014 | 01:36 PM
Technical Hero
They connect to the cabin wire harness. However I doubt many people in here will be able to get you the part number as in the States we don't have Honda City's or RHD cars at all.
Old Jun 20, 2014 | 05:18 PM
viperjng's Avatar
Thanks for the help guys got the harness from thailand
viperjng
Jun 16, 2014 06:08 PM
S3XUN8
Dec 20, 2011 05:49 AM
justhatched231
Jun 24, 2010 06:07 PM
JKov240
Feb 6, 2007 11:46 AM
