After swap questions
Old May 5, 2004 | 11:10 PM
emoney9's Avatar
Default After swap questions
swaped a '00 B16a2 in my 97 hatch, running obd1 ecu, runs perfect...ran open header for 2 days, CEL goes on...throws code: 01 (o2 sensor), and code 14 (iacv)...bolted on '00 Si cat, stock DX piping and DX muffler, CEL went away...today i drove around for a while, was hot (not sure if this matters and sat in traffic a lot) CEL went on again...same codes as before (01 and 14)...came home shut off car, started again, CEL was gone...let it idle for 4 minutes, still no CEL...drove around tonight for 30 minutes, no CEL...my question is, why does it throw CEL's every once in a while? could my IAVC be bad? am i running too rich that it would trip my o2 sensor? running open header gave me no backpressure, now does a stock DX exhaust set up give me too much back pressure? is this something to worry about...also when the CEL goes on, the car idles perfect and runs perfect...any and all help is appreciated
Old May 6, 2004 | 05:36 AM
emoney9's Avatar
Default Re: After swap questions (emoney9)
so no one ,huh?
Old May 6, 2004 | 09:41 AM
egsleepercivic's Avatar
reset your ecu, remove negitive battery cable for 5-10 mins
see if you still gets codes
Old May 6, 2004 | 11:24 AM
emoney9's Avatar
Default Re: After swap questions (egsleepercivic)
already reset ecu...CEL's are not on after i shut off car then start up again...yesterday was the first day after 4 days that the CEL went on...and when the CEL is on the car runs perfect...?!?!?!?!?!?!?!?!?!? have been driving the car today and no CEL...
MonkeyPuzzle
10
Aug 6, 2015 06:37 AM
98greensi
Aug 29, 2009 08:23 AM
Nyceguy17
Jun 11, 2005 02:49 PM
