Swap help???
Old May 12, 2004 | 08:44 AM
sparcob17a1's Avatar
Default Swap help???
I'm putting a b16a1 into my 1990 integra. Everything is hooked up but it's not turning over. I don't think it's getting any fuel. It is getting spark to each cylinder. The fuel makes it to the sending unit by the firewall but I don't think the injectors are squirting. The car originally had a b18a in it and had a b17 swap done a while ago so the wiring for vtec was all done. We're using the wiring harness that was used with the b17, which is the original b18 harness. I'm pretty sure the injectors that were used for the b17 were the original b18 ones. Should I be using the b16 injectors or the b18 injectors?? Any other reason why the injectors wouldn't be squirting fuel??
Old May 12, 2004 | 10:15 AM
WHITFIELD-TUNED's Avatar
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
Default Re: Swap help??? (sparcob17a1)
check the pgmfi relay under the dash
Old May 12, 2004 | 12:18 PM
Default Re: Swap help??? (HOOKUPS)
So the car was converted from OBD0 to OBD1 when the b17 was put in and is now using a P61 ecu. Can I just take the injectors and the distributor from the b17 and put them on the b16 using the P61? Or will I have to get an OBD1 to OBD0 conversion harness and use the PW0 ECU and a resistor box??
phatboyzef2
26
Dec 23, 2010 12:30 AM
finallyturboed301
10
Dec 8, 2006 06:35 AM
the.hamburglar
Mar 11, 2006 06:10 PM
contentious
11
Oct 28, 2005 12:04 PM
markedOO1
Nov 26, 2001 07:50 AM
