Wiring GSR into EG Questions
Old 05-04-2004, 02:18 PM
JDMSi92's Avatar
Default Wiring GSR into EG Questions
Helping a buddy put a b18c1 into his si eg. What do we need to do as far as wiring to obd1? We are using eg wiring harness and a p28 chippped. Any info on wiring will greatly help. Also if anyone has any chipped ecus or can burn and uberdata ecu for us that would be great. Thanks!
Old 05-04-2004, 07:11 PM
VtecDeMoN's Avatar
Default Re: Wiring GSR into EG Questions (JDMSi92)
Search. Then again you could just think about it, what does a b18c1 have that a d16z doesn't? Oh and if you're looking for an ecu, my brother just picked up an eprom burner and we will be doing uberdata programs shortly.
Brian
Old 05-04-2004, 10:31 PM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMSi92 &raquo;</TD></TR><TR><TD CLASS="quote">Helping a buddy put a b18c1 into his si eg. What do we need to do as far as wiring to obd1? We are using eg wiring harness and a p28 chippped. Any info on wiring will greatly help. Also if anyone has any chipped ecus or can burn and uberdata ecu for us that would be great. Thanks!</TD></TR></TABLE>
you can use the Si harness on the B18C1, if the motor is OBD1 spec. You'll have to extend a couple wires, but the Si harness will work nontheless.
Hit me up if you need an eprom chip burned
5poonhatch
05-30-2005 06:28 AM
Sassafrass
09-04-2004 03:38 PM
DannyNada
11
05-20-2004 01:17 PM
Hoopsta903
08-21-2002 12:26 AM
Quick Reply: Wiring GSR into EG Questions
