WTF is wrong w/my Gsr swap? HELP!!!
Old 05-13-2004, 05:32 PM
its WANG yoO's Avatar
Default WTF is wrong w/my Gsr swap? HELP!!!
when driving at steady RPM's(3k,4k...etc) my car has this shudder to it...it feels like its missing while driving...and also...my lights dim and brighten also...someone help me figure this out!
Old 05-13-2004, 07:12 PM
PA MATT's Avatar
Default Re: WTF is wrong w/my Gsr swap? HELP!!! (SwapWhore101)
bump..somebody help the swap *****!
if its skipping, check ur plug...mine was and that was the problem
Old 05-14-2004, 12:51 PM
Default Re: WTF is wrong w/my Gsr swap? HELP!!! (ebpG2)
bump!
Old 05-14-2004, 08:35 PM
porschekremer's Avatar
TTT
Old 05-14-2004, 11:11 PM
Zerob16eg's Avatar
your lights dimming and brightening sounds like an alternator problem.....go have it checked at schucks. they do it for free. as far as your motor
1.check yout timing
2.check your plugs, they may be fouled out
3.check your cap rotor/test ohms from your plug wires.
Old 05-15-2004, 04:46 PM
my house has wheels on it
BrokeAssWhiteboy's Avatar
Default Re: (Zerob16eg)
i wad the same problems in my car, turned out to be the ecu.
Old 05-15-2004, 05:18 PM
slowazzhatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zerob16eg &raquo;</TD></TR><TR><TD CLASS="quote">your lights dimming and brightening sounds like an alternator problem.....go have it checked at schucks. they do it for free. as far as your motor
1.check yout timing
Old 05-16-2004, 12:47 PM
Default Re: (slowazzhatch)
i put new plugs in and fuel filter...timing is correct as far as i can see...i never touched the crank/cam gears...the distributor is set centered on the slots...
do i have to take out the alternator to have it checked?
Old 05-17-2004, 01:21 AM
carsaregood's Avatar
Default Re: (SwapWhore101)
you don't have to take it out, you can just bring your car there and they'll bring out a hand held tester to check out your charging system.
Old 05-17-2004, 03:35 AM
Default Re: (carsaregood)
sweet...
Taylor7288
01-30-2008 03:05 PM
994door
06-22-2007 01:37 PM
b18cEK
11-05-2006 06:17 PM
pacifico
08-28-2004 08:37 PM
Lookincrazy
05-15-2003 01:50 AM
Quick Reply: WTF is wrong w/my Gsr swap? HELP!!!
