b16a Code 16
Old May 3, 2004 | 05:54 PM
4gCRX's Avatar
Default b16a Code 16
I swapped a b16a into my 91 crx hf about 2 months ago. I have had the code 16 ever since I first turned the key. About 2 weeks ago I picked up the TPS code the same day I tried out a VTEC indicator light which I promptly removed. Performance is there through all the gears(Runs great!) but it is running rich. I failed emissions test: HC target 175ppm My car 270ppm CO target .99% My car 5.66%.
I have replaced the Main relay with OEM, switched from Bosch to NGK plugs (Bosch plugs were clean at that time)gapped at .043, timing set at 16 degrees, fuel pressure @ 40 psi(B&M regulator), new fuel filter, replaced all vac lines, I can hear all injectors click (screw driver), replaced injector seals, when I pull the plugs on injectors one at a time the car runs rough, each injector has 2.5ohms resistance, noid light lights up on all, 4wire O2 sensor heats up as soon as I turn the key, already replaced 2 month old cat with new (rotten egg smell from time to time), and I have continuity in all fuel related wires. I did find the pvc valve was plugged and replaced it with new. I've reset the ecu many times, pull both battery cables and hazard fuse and let sit for 20 minutes.
Any ideas? Like I said, car runs real strong.
Old May 3, 2004 | 07:29 PM
queez's Avatar
Default Re: b16a Code 16 (4gCRX)
i just had a CEL code 16.. turns out one of the prongs in my injector plug was a little wide and would loose contact and trip a code i just bent it tighter now i havent triped a code since
Old May 4, 2004 | 06:53 AM
4gCRX's Avatar
Default Re: b16a Code 16 (queez)
Thanks, I'll check them out.
Old May 4, 2004 | 10:57 AM
4gCRX's Avatar
Injector plug "prongs" all look good.
Old May 4, 2004 | 12:26 PM
queez's Avatar
they might all look good, but take a tiny flat head screw driver and make sure they are tight together. so they maek good connection..
Old May 4, 2004 | 03:03 PM
4gCRX's Avatar
The injector plugs are tight.
Old May 5, 2004 | 06:06 AM
4gCRX's Avatar
Any other ideas? Anyone?
Old May 5, 2004 | 07:44 AM
michael O's Avatar
I got the same problem...
tom p
Oct 12, 2011 03:58 AM
maxboost_50psi
Feb 11, 2007 08:18 PM
raiden571
May 18, 2005 10:54 AM
Ekay Jay
Apr 14, 2005 06:30 PM
adeline
Apr 11, 2005 07:13 PM
