crx b16 swap troubles that i am having
this is a b16a into a crx OK first thing my injectors are not firing I get fuel to the rail and I get pressure good pressure but the injectors are not firing I checked everything it all seems good but im still confused I pulled the rail and I zipped tie the injectors in to see if they fire but they don’t and as soon as I cut the zip tie the injector flew and fuel went everywhere so I know I have fuel and pressure and I have good spark and I have between 163 to 161 compression on all cylinders.... And my wheels wont spin it seems like the are locked I try to hold the clutch down they wont spin they feel locked... its wasn’t like that until I swapped the motor in it was fine before I put it in... Any help a suggestion will be great... Thanks
Re: crx b16 swap troubles that i am having (crazyrex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyrex »</TD></TR><TR><TD CLASS="quote">on all cylinders.... And my wheels wont spin it seems like the are locked I try to hold the clutch down they wont spin they feel lockedsuggestion </TD></TR></TABLE>
You need the take out the Dust Rings in your hubs. Take the axels out and pry out the Ring on the inside of the hub. I had the same prob. The wheels wouldnt budge
You need to take out your injectors and test each one, hook up a ground and then a positive. Use your battery for a power source. They should click.
crxmadness
10
10-04-2012 10:48 PM
