h22 eg .. alternatives?
Questions..... i have a set of RC 310's saturated injectors, i was wondering if i can use these in my H22A motor ofcourse not hooking up the resistor box with it.... I was told that it may work if i dont use the resistor box, but im in doubt since im using the P13 ecu, another question do i really need the egr solenoid? I notitced my throttle cable is way too long even if i flip the cable bracket it does not reach, what throttle cable will work best for Eg's with h22 if i were to buy a new one..
Re: h22 eg .. alternatives? (spooned out)
Yes the RC's will work, you will need to take off the resistor box since they are saturated and not peak and hold injectors.
As for the EGR, it's pointless unless you're wanting a bone stock set up and emissions crazy. The stock EG throttle cable will work using the prelude throttle bracket turned backwords.
Check my thread in the Hybrid forum at the top and you'll see.
HTH.
HTH.
Re: h22 eg .. alternatives? (poison)
okay i noticed you have one for the use with resistor box, now since i had my harness wired up to use the resistor box do i have to undo it? or can i leave it wired up and just not pluged to the box itself and just throw in the RC's .. the mjaority of my plugs are plugged but its the tubing that gets kinda confusing, IAB/EGR/EVAP etc... does anyone have a simple sketch or diagram or pictures where these tube connect too? ... i read your post poison pretty helpfull info, still alittle confused on the tub connections at the intake mani.
StickyDilJoe
04-13-2003 12:55 AM
