h22 in to 97 accord ex problem
i am hoping that someone can give me some help with my problem. i have a 93 jdm h22a in a 97 accord ex. I have rewired the distributor to obd1 because i am using the prelude ecu. The motor starts and idles, but when i try to rev it the engine seems like it is choking and wants to stall. The rpm will get down below 100 but comes back up to about 600 or so. I just checked the timing today and everything is lined up where it should be. Can anyone think of what i am doing wrong. Any help is appreciated. THanks
Re: h22 in to 97 accord ex problem (AzNpRiD3)
are you getting a check engine light at all?
what ecu are you using exactly?
have you thought about getting a conversion harness (OBD2a>OBD1) and running an OBD1 P13 ecu?
Re: h22 in to 97 accord ex problem (Katman)
yea i am getting a check engine light and i am using the obd2-->obd1 conversion harness with the p13. i am in the process of checking the light, i just wanted to see if anyone knows off the top of their head what the problem might be.
gibbythered
01-16-2008 04:05 AM
CamGriffin
03-22-2004 10:46 AM
