B18C rev problems
Old May 6, 2004 | 05:28 AM
94RedEGCoupe's Avatar
Default B18C rev problems
Here's my problem I putin a B18C into my 94 civic and it was slow, about a 16.2 quarter mile. Last week I installed an Air/Fuel ratio gauge and anytime it goes above 4,000 r.p.m. the gauge says I'm running lean and the car has absolutely no power at all. I have switched the fuel pump, the fuel filter, and the O2 sensor, and nothing has changed. Someone has told me it might be the computer. Has anyone had this problem or give me some advice?
Old May 6, 2004 | 07:20 AM
ki3t's Avatar
This user can set his title.
Default Re: B18C rev problems (94RedEGCoupe)
I'm assuming your B18C is a JDM ITR or GSR? What ECU are you running? I have the JDM 98+ ITR engine in my 93 coupe. I'm running a P28 chipped.
Old May 6, 2004 | 08:03 AM
Default Re: B18C rev problems (Ki3t)
It's a JDM GSR. I am running the p72 ECU that came with the motor
Old May 11, 2004 | 02:10 PM
radteg's Avatar
can u hear the vtec at all?cuz if u aren't getting any vtec that might be why but if not then take it somewhere.
Old May 11, 2004 | 03:50 PM
Turbo E's Avatar
you may need to switch 2 wires if you are using the civic wire harness,
Old May 20, 2004 | 05:51 AM
Default Re: (Turbo E 604)
turns out it was just a clogged fuel line between the fuel filter and the fuel rail
jr_soliz2010
Oct 8, 2012 06:56 PM
tronic
Nov 19, 2011 06:50 PM
Nhannerds
Dec 16, 2007 08:48 AM
