ls/vtec swap question?
im doing a ls/vtec swap. i have the b18b block and i have teh gsr head and i wnat to put ctr pistons and then do new injectors and head gasket adn then run high octane fuel. Is it safe to do that b/c compression is gonig to be at like 12.7:1?
Ok, what now?
GSR head will yield a higher compression than a PR3 ITR or B16 head. That along with CTR pistons will bump compression up pretty high, and being that said, I would run high octane fuel regardless.
So, what's your question?
that would solely depend on how high of compression you want. CTR compression is higher than the pr3's
also, you are going to potentially run into more problems with the higher compression pistons(CTR) if you are not running high enough octane all the time.
When the engine starts a knocking...you're fucked!
wut kind aknockign u talkign about wonder if that wut mine is..pleas explain wut kind of knocking... >< i have an stock ls...but after i took shop got back..makes kinda funny noise not loud knocking but sounds liek timing belt or something is it knocking like loud? mines jus kinda quiet knocking like tic tic tic tic tic kinda fast but gets drowned out and mid to high rpms..can u help me out haha
JDMlyfestyle
11
Feb 16, 2005 01:36 PM
sir91
Apr 6, 2004 09:48 PM
function83
10
Jul 11, 2003 03:45 AM
