for the H22er's.......
Old May 6, 2004 | 08:39 PM
SpeedingHatch's Avatar
Default for the H22er's.......
In first I am getting premature rev limit, like 6000. Its only in first. What the **** could it be? Thanks
Old May 6, 2004 | 10:50 PM
poison's Avatar
Default Re: for the H22er's....... (speedinghatch)
Any codes? Could be oil pressure, grounds, etc.
How long this been happening?
Old May 7, 2004 | 06:53 AM
Jason kiDD's Avatar
Make sure that the car is fully warm first and check your oil to make sure you have enough..
Old May 7, 2004 | 07:11 AM
Default Re: for the H22er's....... (Jason kiDD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jason kiDD &raquo;</TD></TR><TR><TD CLASS="quote">Make sure that the car is fully warm first and check your oil to make sure you have enough.. </TD></TR></TABLE>
It was warmed up. Checked oil, everything looks good. No codes
Old May 7, 2004 | 10:40 AM
C M S's Avatar
Check your TPS sensor, the pin may have come out or not all the way in. Probably not the TPS cause you say only in first but worth a try.
Old May 7, 2004 | 11:38 AM
Default Re: for the H22er's....... (1SICJDM)
thanks. I checked everything, made sure solid connections and everything was hooked up. Made some minor adjustments, took it for a spin - worked like a charm. Everything is A okay. Thanks for the help
Old May 8, 2004 | 12:09 AM
jdmcivicferio's Avatar
do you have a VAFC?
Old May 8, 2004 | 10:04 AM
Default Re: for the H22er's....... (jdmcivicferio)
yes, but I am not tuned yet
Old May 8, 2004 | 12:36 PM
hondaZvic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedinghatch &raquo;</TD></TR><TR><TD CLASS="quote">thanks. I checked everything, made sure solid connections and everything was hooked up. Made some minor adjustments, took it for a spin - worked like a charm. Everything is A okay. Thanks for the help </TD></TR></TABLE>
made some minor adjustments to what? what was the problem?
Old May 14, 2004 | 08:30 AM
93H22ACX's Avatar
Default Re: for the H22er's....... (hondaZvic)
yes please tell
twkdCD595
Jul 1, 2008 05:06 AM
Delano5050
11
Sep 4, 2006 05:22 PM
XxRoCkMaNxNEOxX
Nov 28, 2004 09:17 AM
redmosquito
Honda S2000
Mar 5, 2004 06:31 AM
IloveNewt
Jan 11, 2004 02:10 PM
