Will a 96 ex engine harness run a 98 b16 ecu with out modification???
I am doing a swap and using a 96 ex harness. I am plugging the harness into a 98 b16 I am assuming that this will work with out a problem. Am I right???
Re: Will a 96 ex engine harness run a 98 b16 ecu with out modification??? (mrtrex)
Well...it depends on if your motor is JDM or USDM...you might have to eliminate/lengthen a few sensors/wires, but as far as plugging up to the ECU, yes it will work just fine. All 96-98 ECU's have the same plug layout to the ECU.
b18_crx
Texas -OK -LA (Sales)
12-04-2012 05:06 AM
ITR.#1446
09-10-2005 04:43 PM
mrtrex
05-03-2004 06:04 AM
