obd2 wiring into a 92civic si!!
Old 05-12-2004, 04:44 PM
92civic_si's Avatar
Default obd2 wiring into a 92civic si!!
can someone link or help me w/ the wirings..thanks!
Old 05-13-2004, 12:10 PM
Zerob16eg's Avatar
what do you want to kno? what obd 2 car are you pulling the wiring from.....more info is needed
Old 05-13-2004, 12:18 PM
Katman's Avatar
Default Re: obd2 wiring into a 92civic si!! (92civic_si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92civic_si &raquo;</TD></TR><TR><TD CLASS="quote">can someone link or help me w/ the wirings..thanks!</TD></TR></TABLE>
The key in doing what your title says, is to use a US OBD2 (96-01) INTEGRA engine harness. It will directly plug n' play into your 92 Si (minus a couple plugs that you won't use anyways). And you can retain the use of an OBD1 ecu too.
Thats it.
Old 05-24-2004, 07:38 AM
92civic_si's Avatar
Default Re: (Zerob16eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zerob16eg &raquo;</TD></TR><TR><TD CLASS="quote">what do you want to kno? what obd 2 car are you pulling the wiring from.....more info is needed</TD></TR></TABLE>
well, i'm droping a USDM 99 gsr motor into my 92 civic si hatchback..the motor is OBD2!
Old 06-04-2004, 01:47 AM
carsaregood's Avatar
Default Re: (92civic_si)
like katman said, its easiest if you use an integra obd2 engine harness because it will plug into your obd1 chassis harness at the shock towers. then you need to wire in the secondary butterflies and knock sensor. since your car is a '92 and an si it is prewired for vtec, so you don't have to worry about that.
that would be the easiest way to run it with an obd1 ecu. if you want to use an obd2 ecu then it gets more complicated. you'd need a conversion harness and would have to wire in some more sensors like the secondary o2, the crankshaft fluctuation sensor (CFK), some evap sensors, i'm not sure what else. if anyone knows how to actually do this to pass smog please share.
black06lude
11-09-2006 08:30 AM
integlspwr2k
07-22-2006 12:04 PM
92civicman
12-06-2004 07:37 AM
eggie75
08-17-2004 09:51 PM
1blownnteg
10
08-04-2004 01:06 PM
Quick Reply: obd2 wiring into a 92civic si!!
