Can someone double check vac lines
91 CRX HF with B16A
I've checked all the vacuum diagrams but I havent seen any with some of the crap next to my MAP sensor Soooo....I just want to make sure I got it all hooked up right. I'm not sure which is the Purge Cut Off valve and which is the Pressure Reg valve. All diagrams I have seen show 2 solenoid valves each with an upper and lower hose fitting. Valve 1 in the pics below has an upper fitting and 2 lower fittings.
Vac line M1 is running from front of TB to MAP
Vac Line L2 (from a T where fuel pressure reg line and back of intake line meet)is running to #2 valve. I tried hooking this line to #1 valve (4th pic) and the car ran like crap.
Look ok?
Modified by 4gCRX at 11:40 PM 5/5/2004
Modified by 4gCRX at 11:53 PM 5/5/2004
Modified by 4gCRX at 12:00 AM 5/6/2004
Look ok?
technine
08-08-2002 02:52 AM
