Swap Questions.
I finally managed to pull off a second LS swap for myself, and after realizing that this is the nicest car I have ever owned...
I was wondering about accessories for LS swaps into a ED Hatch.
Accessories like drop springs that can carry the extra load.
Who has some? What are you using? My car walks all over the road.
Also, I was wondering if anyone ever bought a prefab shifter linkage.
I made mine, and I am thinking about buying a prefab instead... Advice?
I did a search, but the spring questions always turned up questions about rates. I just need to buy some that are made to stabilize my car better than it is.
Thanks.
IT
EDITED: Sorry about the dumb title. I meant to title it swap accessories.
Thanks.
IT
I assume that the title is stopping anyone from replying.
I just wanted suggestions for which spring would carry the heavier engine that I swapped in my car, and if anyone has used a prefab shifter linkage.
If anyone wanst to answer please do. Searching only makes me more confused about which spring rate that I need.
IT
IT
i was dealling with the same issue when i put my h22 in my ek4. i bought the tein flex and the guy from tein said if i didn't like how it hadled on stock set up for the ek i could send the fronts to hime and he wouold re valve them for me. so u might try getting them revalved or check into some stiffer struts. GOOD luck with that
93EJ2
Dec 15, 2007 02:17 AM
