b20 v-tec which head
Old May 11, 2004 | 12:24 PM
rex91si's Avatar
Default b20 v-tec which head
I have a 91 crx si and I was wondering about a hybrid motor I have heard of b16, b18 head swaps but i want a 2.0L daily driver with v-tec.
Old May 11, 2004 | 12:48 PM
WHITFIELD-TUNED's Avatar
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
Default Re: b20 v-tec which head (rex91si)
YOU CAN USE EITHERE THE B16 OR GSR HEAD, IF YOU HAVE ACCESS TO BOTH I RECC. THE GSR FOR MANY REASONS...
Old May 11, 2004 | 01:41 PM
poison's Avatar
either/or. I'd go with a B16 head just out of preferance.
Old May 11, 2004 | 09:08 PM
saleensolution's Avatar
Default Re: b20 v-tec which head (poison)
if im not mistaken the b16 head bumps compression a little bit more than the b18
Old May 12, 2004 | 09:48 AM
poison's Avatar
Default Re: b20 v-tec which head (saleensolution)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by saleensolution &raquo;</TD></TR><TR><TD CLASS="quote">if im not mistaken the b16 head bumps compression a little bit more than the b18</TD></TR></TABLE>
Nope that's the B18 head that does that.
Old May 12, 2004 | 10:07 AM
DYNO-PRO
the b18 head bumps CR up .2 it also has different port angles that stock to stock out perform the b16 head on the dyno
Old May 12, 2004 | 11:50 AM
rex91si's Avatar
but what about room under hood would i have to remove a/c or relocate battery. also what about weight over stock d16.
Old May 18, 2004 | 12:03 PM
DYNO-PRO
Default Re: (rex91si)
both head measurments are the same
Old May 18, 2004 | 02:10 PM
Bowen's Avatar
Default Re: (HOOKUPS)
b18 i would go with and did go with
b16 is so much cheaper it might be worth it and theres the debate on better flow on the b16 head
Old May 18, 2004 | 04:25 PM
DA6righthand's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rex91si &raquo;</TD></TR><TR><TD CLASS="quote">I have a 91 crx si and I was wondering about a hybrid motor I have heard of b16, b18 head swaps but i want a 2.0L daily driver with v-tec. </TD></TR></TABLE>
...i would go with a b16 head. i watched this best motoring vid that had a b20 block with a b16 head and it had the norm i/h/e and was hittin 170 no prob. thats what im gna build for the project im gna start next yr.
thanx
justin
Old May 18, 2004 | 05:44 PM
POWERLINEDOHCtor's Avatar
check this out http://www.alaniztechnologies.....htmlandhttp://www.alaniztechnologies.....html
one of the reasons i went with an ALANIZ competition port b16 head.
not trying to say that the b18 is not good, its just something to look at
Modified by POWERLINEDOHCtor at 6:55 PM 5/18/2004
Old May 19, 2004 | 09:53 AM
DYNO-PRO
Default Re: b20 v-tec which head (POWERLINEDOHCtor)
agreed when you fully build the head they are the same but stock to stock i favor the GSR ... just an opinion from numerous dyno tests, flow #S are cool to look at but in the end we all want HP
Old May 19, 2004 | 12:23 PM
I3ackfire's Avatar
Default Re: b20 v-tec which head (HOOKUPS)
I would go with GSR head. Many reasons for this choice, there are many articles about this in the archived threads!
blanco617
Aug 7, 2007 04:36 PM
ProjectEF9SI
Feb 17, 2007 04:20 PM
torqueMONSTER
Jul 28, 2005 05:06 PM
92integracrv
Sep 30, 2004 03:32 AM
Turbohatch
Oct 14, 2001 07:41 PM
