What is this?
Old May 3, 2004 | 05:51 PM
tencan's Avatar
Default What is this?
I have this cable that i know plugs into the transmision, but on the d tranny where it plugs into is close to the firewall. Now i have a b16 in it and the cable doesnt reach to where it belongs on the b tranny.. what should i do... I dont even know what it is called but i do know that if its not in the **** wont start....any help will be appreciated .. In the lower right hand corner ,, the cable that appears to in front of the fuel line....
Old May 3, 2004 | 06:04 PM
chad's Avatar
Moderator
Default Re: What is this? (tencan)
an arrow would help!
Old May 3, 2004 | 07:12 PM
brian g's Avatar
Speedometer cable
Old May 3, 2004 | 07:43 PM
Echo7847's Avatar
Default Re: What is this? (brian g)
Looks like the VSS (Vehicle Speed Sensor)
Old May 3, 2004 | 10:35 PM
jdmcivicferio's Avatar
Default Re: What is this? (Echo7847)
VSS, the car will work but no VTEC
Old May 4, 2004 | 06:24 AM
tencan's Avatar
Default Re: What is this? (jdmcivicferio)
ok So now that I know that its the vss is there a longer one becasue its short like a foot. Do i have to get one from another car, like say a 90-93 teg.
Old May 4, 2004 | 03:34 PM
APEX CRX's Avatar
which b16 tranny are you using?
Old May 4, 2004 | 07:04 PM
VtecDeMoN's Avatar
Even though you don't say, I'm assuming you have a EF or DA? It would really help if you would provide at least this information when asking for help. To me it sounds like you are trying to swap a hydraulic transmission in there, that's why your vss isn't reaching, among other problems you are going to run into(ie cable tranny car and hydro tranny).
Brian
Old May 4, 2004 | 08:48 PM
brian g's Avatar
It's not the VSS, that's built into the speedometer on your car. It's your speedometer cable. Buy one from a 90 Integra, it's longer.
brian g
Old May 5, 2004 | 05:12 AM
tencan's Avatar
[QUOTE=brian g]It's not the VSS, that's built into the speedometer on your car. It's your speedometer cable. Buy one from a 90 Integra, it's longer.
Sorry about the missing information. It is a 88 hf crx. and its a cable transmission. I now know that it isnt the vss. the vss on this tranny is electric.
Im assuming its the speedocable. Ill just get the one from a 90-93 teg , and as far as the electric vss , what should i do about that? i dont have a plug on my harness for it. THanks for all the info.
Rich
Old May 5, 2004 | 06:54 AM
brian g's Avatar
Take the one out of your HF tranny and put it in the B16 tranny.
brian g
Old May 5, 2004 | 07:19 AM
tencan's Avatar
Ok there is a spot on the front of the tranny that looks like the cable could fit into and at the back of the tranny it has the vss clip. on my hf tranny there is only a copper nipple (sortof) that the cable pluged into..its not bolted onto the tranny. Ill take another look at the d tranny i have... thanks again.
Old May 5, 2004 | 07:49 AM
brian g's Avatar
On your hf tranny the copper nipple should have been held down by a steel clip and a 6mm (10mm head) bolt. It's called the speedometer gear. The speedometer gear pulls out of the tranny and can be used in place of the VSS/speedometer gear on the B16A tranny. Then you can put the cable into the new speedometer gear, if it doesn't reach then use the longer 90 Integra speedometer cable.
brian g
Old May 5, 2004 | 11:03 AM
tencan's Avatar
Thanks alot. Your help is greatly appreciated. Ill get to that when i get outa this hell called work..
Rich
swint2007
Apr 3, 2010 11:14 AM
philkehn
Nov 19, 2006 10:08 AM
jdm_lover
Nov 5, 2004 12:22 AM
^MikeG
Oct 10, 2004 07:00 PM
