GSR dash into civic
Old May 13, 2004 | 10:52 AM
Zerob16eg's Avatar
Default GSR dash into civic
ok i have already done this into my car; however, when i did mine i just used the whole gsr harness and instsalled it into my hatch......i have a friend that has just the dash and wiring and i kno that you can cut the plugs that go into the fuse block and re-pin them. does anyone have a wiring conversion diagram or kno a site where i can get the wiring diagrams for both 92 civic and 95 gsr so i can re-pin them. any help is appreciated thanx!
Old May 13, 2004 | 12:21 PM
Katman's Avatar
Default Re: GSR dash into civic (Zerob16eg)
DC2 dash into EG = bad idea.
Old May 13, 2004 | 03:31 PM
Zerob16eg's Avatar
why? i have done it into my car and i have had absolutely no problems. if you kno what your doing there is no bad idea. thanx for the free bump though! anyone with some diagrams?
Old May 13, 2004 | 08:22 PM
saleensolution's Avatar
Default Re: (Zerob16eg)
i happen to like my dc dash in my eg....no wiring maps for though sorry
Old May 13, 2004 | 08:53 PM
Zerob16eg's Avatar
Default Re: (saleensolution)
it is cool. how did you do your wiring? thanx for the bump
Old May 13, 2004 | 09:08 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zerob16eg &raquo;</TD></TR><TR><TD CLASS="quote">it is cool. how did you do your wiring? thanx for the bump </TD></TR></TABLE>
i cut the plugs off of the teg cluster and hard wired them in
Old May 14, 2004 | 02:55 AM
Zerob16eg's Avatar
Default Re: GSR dash into civic (1993sir)
up for some diagrams
Old May 14, 2004 | 06:24 PM
Zerob16eg's Avatar
Old May 15, 2004 | 10:43 PM
Zerob16eg's Avatar
Old May 19, 2004 | 02:17 PM
92civic_si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zerob16eg &raquo;</TD></TR><TR><TD CLASS="quote">ok i have already done this into my car; however, when i did mine i just used the whole gsr harness and instsalled it into my hatch......i have a friend that has just the dash and wiring and i kno that you can cut the plugs that go into the fuse block and re-pin them. does anyone have a wiring conversion diagram or kno a site where i can get the wiring diagrams for both 92 civic and 95 gsr so i can re-pin them. any help is appreciated thanx!</TD></TR></TABLE>
i'm planning on doing the same thing too..what year was ur dash and hatch? does it plug right in? thanks
Old May 23, 2004 | 01:12 PM
Zerob16eg's Avatar
does not plug in......took me a while to figure out what i wanted to do. alot of modification.
Old May 24, 2004 | 07:21 AM
92civic_si's Avatar
oh! well free bump!
Old May 24, 2004 | 12:27 PM
Zerob16eg's Avatar
Default Re: (92civic_si)
thanx for the bump.....if you need any help with your conversion then pm me and i will do my best to help you out.
Old May 24, 2004 | 03:04 PM
showtymers619's Avatar
* B A N N E D *
ask liam hes done it to his hatch
Old May 24, 2004 | 08:07 PM
Zerob16eg's Avatar
is liam his screen name? thanx
Old May 26, 2004 | 11:27 AM
94si94cx's Avatar
There are plenty of pinouts on here if you search, that's how I found what I needed when I did my conversion.
BTW - I used the Civic harness so the large plugs would plug in. I just wired up the plugs that did not plug in (Rear defrost, cluster, dimmer switch etc..)
Old May 26, 2004 | 12:33 PM
Zerob16eg's Avatar
Default Re: (94si94cx)
i have done alot of searches and have not found out what i wanted to kno.....i want to do this conversion by re-pining the 3 plugs where the dash harness plugs into the fuse block......thumbs up for another eg with a dc2 dash.
*Bump*
video_voide
Feb 26, 2018 06:41 PM
gummiegorilla
Jul 30, 2009 07:32 PM
