car wont go to gear when its running
i have a jdm h22a swap with a jdm accord tranny. hers the problem when tha car is on it doesnt go to gear but whn its off it goes to every gear. i got a brand new six puck,flywheel and throw out bearing. i need u guys help on this one.
Re: car wont go to gear when its running (h22silvia)
OK the last time i've had this problem, my slave cylinder was bad. So what we did was bought a junk yard slave and put it on, bled the lines well, and it worked and shifted fine. The other time i had this problem, my clutch actually siezed up on my flywheel, thats right, ive never seen or heard of it happening to any of my friends, but my car had been sitting for awhile and the clutch was just locked up on the flyhweel. We ended up taking the tranny off and taking the clutch off, ( hit with a hammer) and just put it back on after a little sanding of the surface of the clutch disc and cleaning the surface of the flywheel (brake cleaner), worked fine after that. Hope this helps i know that problem had me stumped
