What Parts to go with GSR Head on ITR Block?
Old 08-12-2006, 03:41 AM
yoorang's Avatar
Default What Parts to go with GSR Head on ITR Block?
hi guys;
i'm preparing on a gsr head which will be put on the jdm itr block, i know the head stud will be B16/B18C5, but i would also want to know what else might be different. thanks!
- head stud for b16a/b18c5
- head gasket for b16a/b18c5
- Timing belt from gsr?
- water pump from itr?
Old 08-12-2006, 11:01 PM
yoorang's Avatar
Default Re: What Parts to go with GSR Head on ITR Block? (yoorang)
help
Old 08-15-2006, 11:09 PM
gakkuken's Avatar
if i remember correctly, you will need gsr tb
Old 08-15-2006, 11:55 PM
turbociviccoupe's Avatar
you use everything from a gsr... water pump, timing belt, head gasket...everything...good luck
Old 08-18-2006, 09:20 PM
yoorang's Avatar
Default Re: What Parts to go with GSR Head on ITR Block? (turbociviccoupe)
thanks for the reply!
just double checked the part # for the water pump, and it turns out the gsr and itr uses the same. thanks again bro!
delsoldrew
06-21-2008 09:00 PM
brent_G
02-22-2006 01:58 PM
salbaje
06-04-2003 09:44 PM
Trey
02-11-2002 06:59 AM
blownsi
10-06-2001 07:59 AM
Quick Reply: What Parts to go with GSR Head on ITR Block?
