WHAT THROTTLE CABLE ON B20VTEC?!?!?!
Old Aug 13, 2006 | 06:45 AM
SpoonEk253's Avatar
Default WHAT THROTTLE CABLE ON B20VTEC?!?!?!
hey you guys im running a b20vtec in my 96 hatch w/ a gsr head but the gsr style throttle cable sit really high and some times hits the hood when i shut it and is to long for the swap....IS THERE ANY OTHER THROTTLE CABLE SHORTER I CAN USE?!?!? BY THE WAY IM USING A SKUNK2 INTAKE MANI!
Old Aug 13, 2006 | 01:47 PM
unknown0001's Avatar
Default Re: WHAT THROTTLE CABLE ON B20VTEC?!?!?! (SpoonEk253)
not sure if this will help you but when I swapped in my b18b into my coupe I used a 90-93 integra throttle cable that I had access to and it worked fine and fit fine, while my d-series one was shorter.
but with your sk2 intake manifold I'm not sure exactly due to how they have their bracket holes lined up at
Old Aug 14, 2006 | 11:12 AM
Andres-eh2's Avatar
you can use an ITR one with the ITR throttle bracket
Old Aug 19, 2006 | 03:12 PM
rukawa1one's Avatar
As long as I dont have to take out any more Metal Gears
try an LS one
Old Aug 19, 2006 | 04:51 PM
ek_chris's Avatar
did you try your stock EK cable? I've re-used mine on a few b-series swaps, worked fine
Ej8_KiD
Oct 29, 2009 09:24 PM
bleakdragonmage
Feb 25, 2007 10:40 AM
SpoonEk253
May 27, 2006 06:20 PM
SpoonEk253
May 20, 2006 11:42 AM
HBP.EH2
Jun 11, 2005 09:13 PM
