Engine won't start
Old Aug 4, 2006 | 02:26 PM
dracos2001's Avatar
Default Engine won't start
just swapped in a B16a in my 2000 DX.... when i turn the key nothing, but if i jump the starter it fires right up...
things i've tried:
DX ecu
JDM P2t ECU
Ex harness
Dx harness
all yeild the same result, won't start with the key... i'm about to wire up a push button start and call it a day...
Old Aug 4, 2006 | 02:32 PM
Relic1's Avatar
you've obviously missed a wire in the wiring conversion in the engine harness, probably the starter solinoid wire.
what have you checked as far as wiring. I hope you didn't just jump the starter and then make this post.
dracos2001's Avatar
Default Re: Engine won't start (dracos2001)
oh, and i've checked the singal wire, it recieves no signal. checked the IG1 fuse under the hood, it looks good. The only thing i haven't checked is the starter relay, but i don't know how to tell if that is good.
Old Aug 4, 2006 | 02:34 PM
dracos2001's Avatar
Default Re: (Relic1)
both ecu's are OBD2b there is no wiring converstion. and what do you mean jump the starter and make this post?
Old Aug 4, 2006 | 02:38 PM
2fast4u831's Avatar
I'm really 2slow
is the engine grounded good? I had this problem a while ago.
Old Aug 4, 2006 | 02:46 PM
dracos2001's Avatar
Default Re: Engine won't start (2FAST4U831)
well i double checked all the grounds, and for the hell of it i hooked up a set of jumper cables to the engine and grounded it on the chassis
i know i'm missing at least one of the grounds, the one from the valve cover to the chassis. was there one from the intake mani? i don't know where all the grounds are on the B16a...
i have the thermostat ground connected and the tranny ground.
but if it was a ground issue why would it start if when i jump it from the battery?
Old Aug 4, 2006 | 02:47 PM
dracos2001's Avatar
and just for further testing i took my DX starter grounded the housing, attached the signal wire and the battery cable wire and tried to spin that starter.... still nothing
Old Aug 6, 2006 | 08:31 AM
CASTUDILLO01's Avatar
check all your wiring
slow_sihatch
16
Aug 4, 2015 04:35 PM
BombSquad91
Apr 17, 2014 02:02 AM
blu eg22
Jun 15, 2007 04:22 AM
