swapping a b16a2 into 98 EK coupe...
ok i bought a 99 si, wrecked. (going to part out the rest) but i have a compleat swap. now my question is.. whats all involved in the wiring? can i use my 98 ex harness, or should i use the 99 si harness? does some one have a write up on this kinda swap. i know it should be a straight forward kinda deal.. but i dont feel like screwing it up.. any and all help would be great.
Re: swapping a b16a2 into 98 EK coupe... (BlueIntegraBoy)
thanks.. but im still confuesed on the wiring.. i know i shouldnt be.. this isnt my frist swap.. but it is my first b series..
Re: (robert_v)
Simply use the harness from the car you're putting the engine into.
If you try and bring that EM1 harness over to the EJ8, you'll have soooo many headaches.
^^^yup
easiest way to do it is going to be to use your current harness, and add in the vtec wiring. there won't be too many changes to the harness... i only changed 3 things on mine when i swapped to b18
Since you have an EX, it should be close to plug and play.
Reuse your harness, which is already wired for vtec and knock sensor.
Then purchase a obd2A-obd2B jumper harness and plug in the '00 si ECU.
Re: (SwapedEX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SwapedEX »</TD></TR><TR><TD CLASS="quote">ok.. now where do i find one of those... i thought it would just plug rite in..</TD></TR></TABLE>
The plugs for the OBD2a and OBD2b ECU's are different.
Re: (SwapedEX)
There are quite few places that sell them.
http://www.jdmshit.com and http://www.Rywire.com are a few.
Re: (robert_v)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by robert_v »</TD></TR><TR><TD CLASS="quote">96-98 gsr ecu or use the type r ecu 96,97</TD></TR></TABLE>
Actually, for integras obd2A goes from '96-99.
Also, I've read that all JDM itr ecus are obd2A, no matter what year.
If you have the '99 si ecu, I'd just buy a jumper harness. They're cheaper than buying another ecu.
Re: (Slopoke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slopoke »</TD></TR><TR><TD CLASS="quote">Actually, for integras obd2A goes from '96-99.
If you have the '99 si ecu, I'd just buy a jumper harness. They're cheaper than buying another ecu.</TD></TR></TABLE> thats what im planning.. and ill be emissions safe that way too!
