b18a1 swap in a 95 civic
hey guys i have a 95 civic ex 5spd with a d16z6. my buddie has an old 92/93 prelude with a b18a1 with automatic in it that hes getting rid of. my question is what all would be needed to switch my 5spd d16z6 for a automatic b18a1. He has the whole car sitting in the drive way i just need to know if there is any special parts (motor mount, etc..) that i need to buy before we start the swap or can i just unbolt the whole engine and tranny from both and stick in the new one? what parts do i need off the acura like axles, gauges, ????? any help would be greatly appreciated. my engine is just about gone with 189k and we have to have second car for my girlfriend and cant really afford to buy the engine of choice. were trying to do this as cheap as possible givin that i can get a new d16z6 for under 500 but really cant afford that right now. thanks
Re: b18a1 swap in a 95 civic (lonestar21)
is it a prelude or integra ,b18a comes in only 90-93 integra ls/gs/rs let me know cause i got this swap in my eg
Former Moderator
There is some confusion going on here:
B18A1 = 90-93 Integra engine
92/93 Prelude would have an F or H series engine which will be a total PITA when compared to the B series swap.
Also ditch the auto idea and find a compatible 5-speed tranny for the engine.
We need more exact info so that we can help you better.
Help us help you!
Help us help you!
as for the swap list
p28 chipped for ls
92-93 driver axel
89 integra pass axel
92-93 mid shaft
95 ls hydro tranny
94-95 mounts motor/tranny (i think)
kepth my harness but really need the ls harness or ex/si cause of the 4 wire o2
ls throttle cable
i think thats it holla if i forgot something
p28 chipped for ls
92-93 driver axel
92-93 mid shaft
95 ls hydro tranny
ls throttle cable
oh yea shift linkage and you will have to cut and turn the pipe so you can get the header to fit
Former Moderator
Re: b18a1 swap in a 95 civic (jdmboi86)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmboi86 »</TD></TR><TR><TD CLASS="quote">as for the swap list
p28 chipped for ls
You don't run a P28 VTEC ECU on an LS engine. Either run the OBD1 Integra LS/RS/GS 5-speed P75 or PR4 ECU.
Also if he runs a hydro tranny he will only need the matching intermediate shaft and 94-01 Integra axles for a 5-speed.
p28 chipped for ls
ok guys it coming out of a 92 integra (ls i believe). im only doing this swap because of money and availibility and i dont want my gurl stranded on the side of the road. i have free access to anything i need off of this car so im going to stick with the auto tranny in it. will the ecu, tranny, axles and all that just bolt up? this will be my first hybrid swap so i need to know everything yall can tell me. thanks again for the help.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 »</TD></TR><TR><TD CLASS="quote">
Also if he runs a hydro tranny he will only need the matching intermediate shaft and 94-01 Integra axles for a 5-speed.</TD></TR></TABLE>
i know but it was a deal at phearable.net and i know i need to run a pr4/p75
and the mid shaft i got a 93 cause it was still bolted on the motor
Re: (instrument)
I HAVE AND IT DOESNT TELL ME EXACTLY WHAT I NEED TO KNOW AND THEY ARE A AFTERNMARKET SITE AND WILL BE TRYING TO SELL ITEMS THAT I MIGHT NOT NEED. THERE HAS GOT TO BE SOMEONE ON HERE THAT HAS SWAPPED THOSE TWO ENGINES AND TRANNYS? HELP?
I HAVE A 92 INTEGRA LS AND A 95 HONDA CIVIC EX. WHAT ALL DO I NEED OFF OF THE INTEGRA TO SWITCH THE ENGINE AND TRANSMISSION INTO THE CIVIC. I WILL BE GOING FROM A 5SPD IN THE CIVIC D16Z6 TO AN AUTO OFF OF THE B18A1 ENGINE. WHAT OTHER PARTS WILL I NEED THAT I WILL HAVE TO BUY? WILL BOTH INTEGRA AXLES WORK ON THE CIVIC? PLEASE HELP
Modified by lonestar21 at 7:53 AM 8/7/2006
Former Moderator
Re: (lonestar21)
Okay now I'm going to repeat myself once again here about the whole auto tranny issue.
Read this next line VERY carefully:
DROP THE IDEA OF SWAPPING THE AUTOMATIC TRANNY INTO YOUR CIVIC!!!
Is that clear enough?
Jeez man people are trying to help you here and you come back typing in all caps, ignoring advice, etc. If you don't want help then fuuck off. If you want help then start doing some searches here and listen to what we're suggesting.
The auto tranny will not bolt into your Civic chassis without having to cut off and reweld the frame side topside tranny bracket, and nobody makes a kit because nobody wants an auto tranny in their Civic. they are not at all performance oriented and if you even get it to line up I doubt the framerail will even have enough clearance for the larger auto b series tranny housing. Please forget about doing an auto B series swap into your Civic.
First of all you'll need to decide this:
Hydro tranny, or cable tranny?
Hydro 94-01 Integra or any 92-00 Civic B16A hydro tranny would be the better choice as it is made for your 92-95 clutch set-up, but if you go cheapie like so many people do and get the cable 90-93 Integra/B16 tranny then you can buy the mount kit and conversion for cable/hydro from http://www.hasport.com as someone already so kindly linked to you. You can mix and match mounts, but the bottom line is that you will need a cable to hydro conversion kit if you buy a cable 5-speed tranny.
Achroth
16
05-02-2016 01:20 PM
Civics for life
06-21-2013 08:42 AM
socialistic
09-20-2008 10:30 AM
