94 B18b1 in 96 Hatch Question
Well I'm already in over my head as it seems because I already put the motor in the car, but then I started thinking that the 94 Integras are OBD1 correct ? Well my EK is obviously OBDII , what would my solution be for this problem? Buying a jumper harness and an OBDI ECU? Any input would be appreciated.
Kyle
Kyle
Re: 94 B18b1 in 96 Hatch Question (BigBoostd)
assuming you're using the single cam engine harness, try and find an obd2a ecu. If not, then a jumper harness and an obd1 ecu.
BoostedH
06-27-2008 10:49 AM
