are explicitspeed360 mounts any good for the h22 swap
i'm trying to gather as much info as possible for this swap. i got a 90 crx dx and wanted to perform this swap. i'm trying to make sure i get everything correct so i don't make any mistakes.
Banned.
Re: are explicitspeed360 mounts any good for the h22 swap (racerose)
I have a lot of vouches of our work...we have sold a lot of the EF 88-91 Civic/Crx H22A motor mount kits. We have done our homework and the end results shows it... great quality kit at a great price...we sleept and ate H22A EF for about 2 months in the developing stages...
In's and Out's with our kit:
Requires no firewall hitting
Requires 1 custom axle
Clears usdm Civic/Crx hood by about 1/2" plenty
Axles:
88-89 Acura Integra driver side axle
88-89 Acura Integra passenger side axle with Accord inner joint
90-93 Honda Accord F series midshaft 94+ may also work also
90+ Accord or 92+ Prelude cable shifter assembly with cables
Modified by ExplicitSpeed360 at 4:11 PM 7/27/2006
Axles:
also i need info on axles shift linkage or shift cables or if it needs both. and what type of suspension do i need to upgrade to for the extra weight. i mean if anybody has a list of parts it would be appreciated
Banned.
Re: (racerose)
list of parts is above there...yes kit includes alternator/tensioner kit your choice of H or D series alternator to run on the H22A engine. As well as the clutch cable/hydro conversion bracket and detailed instructions with pictures and I am here to help assist through the swap from A to Z since I have done it...
EF H22A motor mount kit:
1 new passenger side chassis mount
3 motor motor mounts, driver side, passenger side and rear
1 rear engine bracket for rear motor mount
H or D series alternator/tensioner kit with hardware
Clutch cable/hydro conversion bracket
and detailed instructions and pictures of the swap...
Banned.
Re: (ExplicitSpeed360)
A decent shock and coilover setup will work well. I run KYB AGX 4 way adjustables with skunk2 coilovers nothing too tricky...
PM me with any other questions we have a packaged deal that includes EF H22A motor mount kit and EF H22A traction bar system...
EnSAn
15
08-05-2006 11:25 PM
alternator, cable, cables, clutch, crx, directions, ef, explicitspeed360, h22, kit, relocation, swap, tranny
