H22 Tranny spins in Neutral ???
I finally got my shift linkage installed for my H22A swap - all thats needed now is the axles. So with the car on stands, I went ahead and started it up to make sure all gears were alright but then I leave it in Neutral and look under the car and see the gear inside the tranny where the axles go is still spinning!
Now when I press the clutch in, it does not do this - is this normal??? I mean once I put the axles in, will it stop doing that or something? Maybe the shifter needs adjusting?
Re: H22 Tranny spins in Neutral ??? (2FAST4U831)
Thanks - Yeah I did a "deep search" and found out that its normal for it to do that with no axles attached - that is kinda wierd though, but its all good I guess
Re: H22 Tranny spins in Neutral ??? (Bense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bense »</TD></TR><TR><TD CLASS="quote">Why are you running your trans without oil?</TD></TR></TABLE>
Yeah, thats what I was thinking too.
Re: H22 Tranny spins in Neutral ??? (DC4_MADMAN)
No, we just started it after we got the linkages installed to make sure it was selecting gears ok since I had to wait on the hubs for the Stage 3 Axles... it was not for long lol
1bar_ek
05-18-2008 04:44 PM
JasinS
12-31-2007 10:20 AM
GayHatch
04-02-2003 08:58 AM
