GSR swap wiring question
I am putting an obd2 usdm gsr into my 94 dx civic. With the motor I got the 96 wiring harness, but it seems hacked up. Could I just use my civic harness and change the plugs on it for injectors and alternator, etc? I know I will have to add in vtec and knock. WHich harness would you use?
i am going to be using an obd1 p72. so you think if i just use my dx motor harness and change out the clips for injectors etc, and add vtec, knock, i will be good?
Technical Hero
Re: (agy2k2)
I would just use the DX harness and add all the VTEC related sensors to the harness including IAB and knock sensor wiring. You can either repin the distributor or use a conversion harness and repin the alternator plug to use the 96's. Also you can just repin the injector harness plugs too.
BigRonDawg
04-24-2006 06:04 AM
