OBD DLC issues
Old Aug 1, 2006 | 02:40 PM
JDMFantasy2k's Avatar
Default OBD1 DLC issues
Ok i'm running a turbo d in my 2000 civic, so i'm running a chipped p28. Obviosly i can't hook a scan tool up to the OBD2 port. So i was thinking of soldering an obd1 honda dlc connector into the conversion harness. That way i could hook up an obd 1 honda scanner adaptor and be able to do cool things.
Only problem, i'm not entirely sure which wires to hook up to. I've looked at a ton of diagrams and i've found two wires so far, light blue, and a green/wht. Now i'm assuming that the green and white is a ground since it's also shared by other sensors, and the light blue is a communication wire. However i can't find anything about the 3rd wire. There are 3 wires right? Also what pins will it hook into. I know the green and white wire hooks into pin D23, but i'm lost on the other 2. Any info would be greatly appreciated.
EDIT: i found the pin for the light blue wire. Any help with the 3rd wire would be great
Modified by JDMFantasy2k at 3:58 PM 8/1/2006
Old Jan 3, 2011 | 05:08 PM
sixfourkiller's Avatar
Default Re: OBD1 DLC issues
i had a question for u where u get your obd 1 honda scanner adaptor. i been looking for one for my 95 integra so i can monitor my engine
gmoneyef
Feb 6, 2007 04:09 PM
gmoneyef
Feb 6, 2007 04:06 PM
jayare05
10
Dec 25, 2004 01:12 PM
SleepnCiViC
16
Oct 30, 2004 11:38 PM
Rae
Jul 2, 2001 10:34 PM
