K20 in EK swap no Spark
recently installed a k20 type S into an ek chasis, using the type s engine harness with the hybrid racing adapter harness(pnp) the motor cranks fine but there isnt any spark. (the ecu type is a type R ecu k20a) any suggestions on what to check?
Re: K20 in EK swap no Spark (civicstar)
if you have a helms manual start with testing the coils, most likely ohm then. Next check wiring to the coils (continuity) from the connector to the pack to the ecu plug if everything there is good then i would say its the ecu
Re: K20 in EK swap no Spark (elusive123)
figured it out, some of the pins were rewired and grounded differently from a perviousmotor that had kpro,
12-21-2004 05:21 PM
