just got a h22a put in my ek, some problems
Old Apr 20, 2007 | 06:36 AM
Shadowz7429's Avatar
Default just got a h22a put in my ek, some problems
hi there guys, i just got a friend of mine to put a h22a engine in my ek. experiencing 2 problems atm.
1. the speedo doesn't work, shows the rpm and such, but not the actual speed and the mileage doesn't go up (obviously linked to the speed). im thinking its maybe the vss?
2. the car doesn't rev passed 6750. im using the prelude ECU with an sst chip tuned on crome.
the conversion was not done by me, so any feedback i will let my friend know.
thanx
Old Apr 20, 2007 | 08:18 AM
Braco11's Avatar
Default Re: just got a h22a put in my ek, some problems (Shadowz7429)
yeah, sounds like your vss. should have a CEL for it. And i believe the lack of a vss may be putting your car in limp mode, thus the reason for the rev limiter. check the vss and see if you have any other CELs while you're at it.
Old Apr 20, 2007 | 03:18 PM
thanx for your help dude!
another Q, i use a prelude vss right? im using a prelude tranny
Old Apr 21, 2007 | 06:10 PM
bump
Old Apr 21, 2007 | 10:57 PM
alphajesse's Avatar
One of the things that controls VTEC engagement is the VSS signal, you have to be over a minimum speed. If the VSS doesn't work, the ECU will hold you to the low-cam rev-limit which is roughly 6700RPM.
Also, if you created a rom in Crome and put it in a Prelude ECU (P13) you're not going to have a working program. Crome only does p28/30/72.
Old Apr 22, 2007 | 04:06 PM
his using a p06 ecu? says it works with crome?
Old Apr 22, 2007 | 07:32 PM
vtecspeed1320's Avatar
Shooting Star
Default Re: (Shadowz7429)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shadowz7429 &raquo;</TD></TR><TR><TD CLASS="quote">his using a p06 ecu? says it works with crome?</TD></TR></TABLE>ok a p13 and p06 are different...and the other thing is the p06 has to be converted to act like a p28.
Old Apr 23, 2007 | 05:34 AM
yep, he converted the p06 to act like a p28
bigmaccrew
Feb 17, 2014 03:59 PM
imperfection_is
Aug 29, 2007 09:21 AM
nonvteclude
Aug 26, 2006 09:55 AM
weekendracer
Mar 5, 2002 02:41 PM
