need help on my EK swap
Guest
Posts: n/a
ok i got a 98 civic hatch and i just got a b18a1 and the guy that had it before me converted it to obd1 then he never used it so my ??? can i use my obd2 dizzy or do i have to get one off a obd2 teg ??? and then do i need the 2000 si rear tranny mount i know you have to on the v-tec motors but i didnt know if i needed to and same ?? about the drivers side mount. he also is giving me teg shifter likage will that work on my hatch thanks
Re: need help on my EK swap (isaacson06)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by isaacson06 »</TD></TR><TR><TD CLASS="quote">ok i got a 98 civic hatch and i just got a b18a1 and the guy that had it before me converted it to obd1 then he never used it so my ??? can i use my obd2 dizzy or do i have to get one off a obd2 teg ??? and then do i need the 2000 si rear tranny mount i know you have to on the v-tec motors but i didnt know if i needed to and same ?? about the drivers side mount. he also is giving me teg shifter likage will that work on my hatch thanks
You COULD use the B18 dist but you will need to shave/cut one of the legs off so it will clear the Vtec solenoid. Its easier and more correct to simply get the right distributor. You will need the 2000 Si rear mount and I have heard the CRV mount works also, but haven't confirmed it. The shift linkage will work fine in your car. The drivers side mount will use the stock D series black bracket.
gotboosthatch
23
01-14-2007 04:10 PM
